Bumpyroad wrote:
pauldub wrote:
If you're going to recoat a fiberglass roof, why wouldn't you recoat the fiberglass side walls????? Just clean the roof and reseal all the penetrations with the sealant that Winnebago calls out. You can look up the sealants that Winne uses in the info on their website. IIRC, they used two or three different sealants on the roof penetrations. They used a flowable silicone around skylights and they likely used a urethane in some other areas. If the silicone around the skylights is unmolested, leave it at is because it's extremely difficult to get anything to stick where silicone has been previously used. You can find the correct sealant information at http://www.winnebagoind.com/diagram/Sealant.htm
or instead of doing it this right way, can get opinions from the web to do something different and unnecessary. after all they know better than the manufacturer
bumpy
1. The roof is not visible, the sidewalls are and coating them would look like poo poo.
2. I purchased the camper used a few years back and it was in rough condition when I bought it and instead of removing the old caulk and putting on new there were layer after layer of caulk added to the old seals. The old top has been damaged in several areas (Hairline cracks in the fiberglass) and it just makes sense to remove all the old caulk/material and put a single seamless covering over it while I redoo the installation of the Solar panels(4), TV Antenna replacement, and vent cover replacement(s).
This forum/post was not created to have people post comments as to whether or not I should do this or to add there opinions on the projects merit. It was created for comments on the products to use for this project and I greatly appreciate those that have added suggestions of that nature.
