brickExplorerSep 06, 2013code readerI have a 97 Newmar Kountry Aire on a Ford chasee. According to the Vin # it is also 97. My problem is I can not find the plug for the code reader. I did find a plug but it is not the right shape. Than...Show More
wa8yxmExplorer IIISep 07, 2013There may be an advantage to OBD 1...Depending on the vehicle (And you WILL need a manual to tell you how to do this)On my 1992 Lumina (OBD 1) All I had to do was connect two pins together with a paper clip and read the flashing light (Like on an Onan Generator)Then look it up.With my OBD II new towed I have to plug in a reader.NOTE.. .Mine was a GM system and because of that I won't even hint at which pins. but if Ford OBD 1 is the same.. Readers sure are inexpensive.
Related ContentWhich Code Reader to Buy ?Full System Code Reader?Location of code readerIf you have a Diesel HD truck - Code readerHandling Invalid HTML Code
