bull1's avatar
bull1
Location of code reader
I have a 1998 Pace Arrow on a Fleetwood chassis with a Triton V10 engine. I have looked under the dash to the left of the steering collum, lifted the dog house and looked under the hood. Can anyone tell me where this code reader plug may be located?
  • Thank you all for your response. I located it with the help of a mirror against the right side of the colum just like you said.
  • Mine was on a hard to see mount on the right side of the column. Some may very well be tucked up under the dash with the wires bundled up.
  • Mine was on the right bolted to a bracket on the steering column. I took it loose and bolted it to the bottom of the dash.
  • I had to use a mirror to see mine even knowing where it is I use the mirror.
  • On my 99 it was to the left, but it's there someplace
  • It is mounted on the right of the steering column about even with bottom of dash. It could still have a plastic protective cap.
