Empty_Nest__Soo's avatar
May 18, 2013
Cold weather condensation solution?
We're looking to buy our first motorhome and trying to put together our list of requirements. It figures to be a used unit for budgetary reasons.
One problem we've had with the travel trailer is condensation in cold weather. I like to go camping in the mountains in late winter/early spring and between cooking, washing, and breathing indoors, the condensation on the single pane windows is terrible. I hope to solve/minimize this problem with the new motorhome.
The best solution I've come up with is dual-pane windows.
Are there other effective methods of reducing/eliminating window condensation in very cold-weather camping?
I would be interested in hearing what else has worked for others.
Thanks!
Wayne
  • The simplest and least expensive solution is a small dehumidifier. I own three. One for my house, one for my RV and one for my boat. They cost from about $100 and up depending on size and features and they work like a gem. Showers, cooking and even your breath can raise humidity quite high in a closed confined area. Without running the AC or furnance a small dehumidifier will dry things out nicely. Put it in the bathroom after a shower and close the door and the room will be bone dry in a couple hours max. They are no louder than a fan, and use very little electricity. Such a deal! With the very high summer humidity in Florida, I run one for a few hours several times a week and my coach never gets damp and musty while stored.
  • We leave both the shower vent and the potty room vent open an inch or two year round always run the shower fan while in use and a few minuets afterward run the ceiling fan year round to improve circulation. Fulltiming three years and no problem with condensation.
  • Hi,
    To stop condensation the temperature of the surface (of glass or walls) needs to be above the dew point.
    Cover the windows from the outside.
    Another solution is a 4 inch strip of 1/2 inch thick Styrofoam insulation along the bottom of the windows--again on the outside. The water condenses on the glass, flows down, hits the warm glass and evaporates back into the air.
    Lowering the relative humidity also helps. Open a window and place an electric heater by it. Open a roof vent.
  • I've used the clear heat-shrink plastic over some windows. It works perfectly, stops all condensation, except it is not very durable. But, the biggest problem is that I cannot put it on the sliding windows that I wish to open (e.g., for ventilation.)
    I do ventilate, but when the outside temp is in the teens or single digits at night, I can only stand so much ventilation.
    I figure the dual pane windows will be as good as the heat-shrink plastic, and probably better. Right now I've got dual pane as a "must-have" for the motorhome. I'm just wondering if I'm overlooking another workable solution.
    Wayne
  • We have dual pane glass in our MH, and the windshield is our big problem for condensation. We do have 2 small very quiet dehumidifiers that we run. One sits on the dash behind the curtains for the windshield, and the other is in the bedroom/bathroom area. We hang all wet towels outside, we use a small squeegee on the shower to get rid of the moisture - helps keep the glass clean too.
  • We had very little, almost no condensation with dual pane windows and vent cracked open. The year before that with a single pane 5th wheel we had to use a dehumidifier even with a vent open. I was surprised at the big difference.
  • byways wrote:
    Ventilate. Ventilate. Ventilate. If that doesn't work...ventilate.
    Seriously, keep a window cracked so water vapor can escape. Some use dehumidifiers as well.
    So are you saying he should ventilate? :h
  • Wayne,
    The very quiet dehumidifier works great for us. Check internet for best price.
    Trainer
    http://www.sylvane.com/soleus-air-dp2-45-03.html
  • Hi--many options, but it all boils down to moving the air and ventilation. We always leave the front and rear roof vent open no matter how cold. Requires a little more heat, but lets the warm, moist air out hence controlling condensation. Covering the windows in some way (we prefer the clear plastic that shrinks with a hair dryer applied on the inside frames) helps too. Good luck!
  • Ventilate. Ventilate. Ventilate. If that doesn't work...ventilate.
