AlwaysDreamingExplorerNov 09, 2017Cold Weather In a Class BWe are traveling north for Thanksgiving. Weather in upstate NY will be from 20 low to 40 high. We plan to keep the Coach heated 55 to 68 degrees. Also, plan to remove the panel to expose the fresh wat...Show More
Pawz4meExplorerNov 10, 2017If you're going to keep the heat at 55 or above then I would use the unit as normal. No need to worry about antifreeze or winterizing.
Related ContentClass As in cold weather?Cold-ish weather campingCold weather, generators, and campgroundshydraulics in cold weathercold weather woo's
