DannyLeininger wrote:
rgatijnet1 wrote:
Yes. After each overnight stop check your tires in the morning before you hit the road and you will find that you have to add air.
I disagree with the above. The correct tire pressure is determined by the weight of your MH and set at about 70 degrees. As the temps drop, so will the tire pressure, but this is factored in by the tire designers.
If your tires are properly inflated in Florida, they will be fine in Missouri.
Do a search for How Tire Pressures are affected by cold Temps and you will find lots of info on this topic/
Enjoy the cold!
Perhaps you should have done a search on tire pressures and cold weather. I did, which is why I posted what I did. Read this whole article from the tire experts. They do not even mention 70 degrees because you set your tire pressure for the ACTUAL outside temperature. I guess it is no wonder that some people have blowouts and then blame it on the tire manufacturer.
As their next to the last paragraph states:
It's important to remember that your vehicle's recommended tire pressure is its cold tire inflation pressure. It should be checked in the morning before you drive more than a few miles, or before rising ambient temperatures or the sun's radiant heat affects it.Tire pressure and temperatureAnother article that says the same thing:
Tires and temperatureI like their statements:
Remember, it's not the tire that supports the load, but the air inside it. And as per Charles' Law, as the temperature decreases, so does the volume of air inside the tire. That causes a drop in pressure as well, which means the tire cannot support as much weight.
If you're starting out in San Diego with 105 psi in your steer tires at 70 degrees Fahrenheit, your tires might be at 90 psi in Bismark. That would put you 15 psi underinflated, or looking at it another way, that tire could be overloaded by as much as 1,000 pounds depending on the tire size, as per the inflation tables.
