aboeck3ExplorerNov 17, 2014cold weather travelI am traveling from a warm Florida to a cold Missouri. If my tires are at the correct psi when I leave Florida do I have to check and add air when I get into cold weather?
big_jim_2Explorer IINov 18, 2014If you are not running maximum pressure now why not add 6-8 lbs. before you leave. Then you will probably be ok whatever the temp.
Related ContentTraveling in cold weathercold weather travelCold weather travelCold Weather TravelCold-ish weather camping
