aboeck3
Nov 17, 2014Explorer
cold weather travel
I am traveling from a warm Florida to a cold Missouri. If my tires are at the correct psi when I leave Florida do I have to check and add air when I get into cold weather?
JimM68 wrote:
I also use a TPMS. With the current cold weather in Northern Illinois, most if not all of my tires are below the set threshold, and the TPMS is NOT happy.
My tires have not loast any air, the air in them just got "smaller" is all...
Next spring it will get bigger again, and the machine will be happy.
Let's have some votes?
Should I:
A ignore the machine
B put air in the tires
C change the machines low limit so it quits *****ing
