dougrainer
Apr 29, 2017Nomad
susblum wrote:
Our 2017 Jayco has a Coleman AC. We miss the Dometic heat pump that was in our Forest River. Thinking of pulling out the AC. Any feedback on upgrading to a heatoump
Is one brand better than another? What about a heat strip. We are sucking down too much propane.
1. Heat Strips are NOT meant to heat an RV, Just take the chill off.
2. Since you already have the RV wired for a RVP(Coleman) just get a RVP HP. You only have 2 choices. Dometic and RVP. Both are comparable.
3. You will have to change the wall Tstat if you go to a Heat Pump.
4. HOW long is your Trailer? If over 25 feet and you have 50 amp service, install the original AC in the Bedroom and install the HP in the living room. Doug
