rod82's avatar
rod82
Coleman 17B
I recently bought a 17b and within 5 months my ac started leaking on inside of trailer..I decided to not keep it level since ...I know have a slight fall to the ac side..still try to leak in.anyone else
  • where did you buy it from, and is it under warenty still?  if so take it and get it fixed instead of putting the fridge at risk, if it is out of warenty, start by taking the inside cover off and making sure the mounting bolts are tight..
  • Hey Rod82, I’ve had a similar issue before. The slight fall could be affecting the drainage, but make sure to check the seals and drain line for blockages. Some folks use leveling blocks under the AC to stabilize it. Hope that helps!
  • Fix the leak? Or clear the drain path
    it’s just condensate.
