dougrainer
Aug 28, 2016Nomad
RVP did not make 15k your year. Ducted models, there is no such thing. The TOP units are ALL the same. Ducted is the Inside plenum package. Usually, when the Start Capaitor fails, you will not get that Umph at the compressor. That Umph is a locked up compressor. You can install a 15k and I would when replacing. You cannot blow out the ducts:B Use this link to determine your correct replacement. Doug
http://www.airxcel.com/coleman-mach/service-support/model-number-changes
38,769 PostsLatest Activity: Jun 25, 2013
