DSDP Don wrote:
Sooooo.....let's say you're getting a new RV and it comes with either a stacked washer and dryer or combo unit for the same price....does that mean many of you with a combo unit would opt for another combo? If so, do you have a combo unit in your home?
Let's be realistic. If your coach only has room for a combo unit, fine, but if there is room for a stacked washer and dryer, it's the only way to go.
If I were buying new, than yes I would go for the stacked for all the reasons stated unless the coach was less than 40'. However, if I were buying used and the coach came with the combo I would not consider changing nor would I assign a negative point to the coach. A combo works just fine, a stacked unit just works better unless the storage space is important.
