lanerd
Sep 24, 2015Explorer II
NeverHome2 wrote:
The HR Endeavor and the Monaco Diplomat are exactly the same. They are the top coaches in the single axle group. The higher coaches have tag axles and are longer. I hope this helps but the coaches built by Monaco before the bankruptcy are of much better quality. If the electronics haven't been updated then they will need it.
The bad bushings in the trailing arms were corrected by 2001. The later coaches have a much more substantial bushing but beware, the Roadmaster chassis had a design defect which caused deflection of the H frames and made steering a nightmare. There is a fix now and it is not very expensive to do.
Sorry, but the Monaco Camalot (and sister units in Holiday Rambler, Beaver,and Safari) were inbetween the Diplomat and Dynasty and was available with and without a tag axle, depending upon the length.
I have never heard of a problem with "bad bushings in the trailing arms" on Monaco products. I googled it and found nothing. Additionally, I also googled "deflection of the H frame"...and once again found nothing. Please provide some substantial info on these two problem...if they do indeed exist.
However, Monaco did start a recall of the trailing arm defect on the following coaches:
Monaco Knight 2002 - 2004
Monaco Cayman 2002 - 2009
Holiday Rambler Ambassador 2002 - 2004
Holiday Rambler Neptune 2002 - 2009
Safari Cheetah 2002 - 2007
Safari Simba RD All Years
Safari Zanzibar/Sahara 2002 -2005
Beaver Baron All Years
The recall affects Rear Suspension Trailing Arms ONLY ON THE R4R and RR4R CHASSIS with the "Monaco Gold" or sometimes referred to as "R-Way" suspension. Monaco started replacing these trailing arms with exact replicas which also were defective.
After the Monaco bankrupcy, a private company (Source Eng) started making an upgraded trailing arm that would replace the defective Monaco unit. These replacements are still availible today.
Ron
