- base1957ExplorerThanks olfsrmer
- olfarmerExplorer IITry 'Winnebago parts.com' in Hanlontown, Iowa. They are not part of Winnebago but handle a lot of Winnebago obsolete parts. I have had good luck with them.
- I am guessing that the plastic plunger broke.
I know it is more work, but could you change them out to ones like this?
Latch assembly - MrWizardModeratorbase1957
Helpful hint
Hold phone sideways like a normal camera
Take picture instead of screen capture
Upload normal horizontal camera picture
Shows more detail without the icons on the vertical picture, better picture - Executive45Explorer III
base1957 wrote:
in fact executive... i looked for the way to do that... and still cant find it ...the only way i was able to do it is because you sent the HERE link... where do i find that in this rv net site?
thanks in advance
Click the HERE above and then hit CTRL D to bookmark the link. Saves lots of time.....Dennis - base1957Explorerenblethen
Moses Lake, WA
had two that broke.. i think someone either tried to break into it or just pulled it real hard.
thanks for your help
Posted: 10/17/20 04:37pm Link | Quote | Print | Notify Moderator
What is wrong with yours? - here is another place that might help you.
RV parts - What is wrong with yours?
- base1957ExplorerThanks for the suggestions so far...i tried Colan amd no luck...
Making a couple may indeed the best idea - base1957ExplorerThanks for the suggestions so far...i tried Colan amd no luck...
38,782 PostsLatest Activity: Sep 10, 2026
