- try Colaw as they have many RV parts both new and old. Send them the photo.
- DrewEExplorer IIYou may well be able to get used but serviceable ones from an RV salvage yard.
Failing that, in your shoes I'd probably see about constructing a replacement part, say by cutting and drilling a piece of square aluminum stock. It doesn't look like too complicated of a piece: an angled end for the latch itself, a hole for the pull rod, and a hole for a cross-pin to catch the spring.
One could also 3D print (or have 3D printed) the bolt of the latch once the design is reproduced in a CAD or other 3D design program; printing in nylon is possible but somewhat tricky and requires a printer more capable than the basic models (and likley an enclosure). I'm not sure PLA or other more common 3D printed plastics would hold up all that well here. - emiddlebExplorerIt in the "Technical Resources" => "Forum Posting and Help" subforum, third sticky down. "RV.net and Picture Related FAQs" posting.
- base1957Explorerin fact executive... i looked for the way to do that... and still cant find it ...the only way i was able to do it is because you sent the HERE link... where do i find that in this rv net site?
thanks in advance - base1957Explorerthanks executive.... no i did not know how
here is the pic - Executive45Explorer IIIA picture helps more than 106 pages of gibberish. If you don't know how to post a picture, simply click HERE, put your picture in the box and copy the link provided into your post......Dennis
38,749 PostsLatest Activity: Sep 03, 2025
