You buy an 8 year old used coach, NOT just any Motorhome, but a REPO, which YOU KNEW. You really think people that turned in a REPO unit took good care of it?????????????????????? Then this is YOUR list that you wanted taken care of which is reasonable.
1. Front (Zone 1) AC Interior water leak.
2. Rear (Zone 2) AC Squealing when starting.
3. Awning Wind Sensor issue (sensor not detected).
4. Water Heater – Still does not always wanting to start.
5. Missing ‘ring’ on Passenger map light.
I assume the dealer took care of THESE issues at no charge to you. If so, you have NO reason to be upset. ALL the other items are not part of YOUR original deal. They came up after the sale and IF any of the major chassis items came up on your drive home at the FIRST time you left the lot, then you should have returned immediately. From your post, those items did not. You purchased a USED REPO unit and expect treatment like you purchased NEW with a full factory warranty. Curious, IF the dealer called you up and stated he wanted you to pay for any problems on your trade in unit that they were getting ready for the new owner, you would gladly write a check to cover those items????? Its too bad you have all these problems, but putting blame on the dealer is not right. ONLY if he had knowledge of those major problems prior to the sale would he be liable. Doug
