prism
Oct 14, 2013Explorer
oldmattb wrote:
Our '98 Monaco has compressor-type air connections at the front and rear of the coach. I replaced them yesterday, so the connectors would be compatible with my hoses and attachments.
The rear connection was compressed air and one side of my air system was emptied when the connector was removed - no surprises there. The front connector was not compressed air. When the connector was removed, it didn't blow or suck, so to speak. In addition, I have a hand-written note from a previous owner that says something like "air connectors: rear/out front/in."
What is the front connector for? Compressor connection to fill the system for compressed air if the engine-mounted compressor fails? Any ideas?
Matt B
If the air will go in to the connection to air up the system if towing required etc then air should also come out should it not? Mine does
38,769 PostsLatest Activity: Mar 31, 2026
