Mr__Jeff
Oct 14, 2013Explorer
We recently required a tow for our Allegro Bus. The tow drive attempted to connect his air to our system through the coupling in the front but could not make a good connection. He then went directly to the air dryer near the compressor and installed his own coupling. He had just about every type coupling/plug combination and knew exactly what to do and how to do it. These guys have seen most everything and will most likely know how to take care of you.
As for your rear connection, go to Home Depot or Lowes and pick up one each of the four different air disconnect plugs. bleed your tanks then try each plug. Return the ones that don't fit and attach the proper one to your hose, or to another coupling that connects with your hose. There are really only three or four couplings used in the industry.
38,769 PostsLatest Activity: Mar 31, 2026
