ROYBUCK's avatar
ROYBUCK
condensation on bottom of fuel tanks
Since it is fairly warm out I went out and was walking around the MH seen some wet spots under MH, bent down the bottom of the fuel tank water dripping of. Is this condensation due to the weather, I have not seen this before. I rained a couple days ago it is wet in places under the MH, but you can see the water bubbles on the tank. Roy
  • The same thing is happening to your engine block and oil pan. I could never keep the rust off the oil pan on my previous coach with a Cat engine.
  • Acting just like a can of cold beverage. The volume of fuel in the tank is going to take much longer to warm, being tucked up under the coach, then the air around it.
  • I filed it up when I parked it, I have exercised the Generator used maybe 5 Gal. It is also parked on a concrete slab.. Thanks
    Roy
  • And, if the tank is not full, the same thing will be happening INSIDE the tank. That is when the temperature of the tank falls to the dew point of the air in the tank, CONDENSATION.
    That is why you always store a coach (gas or diesel) with a full fuel tank.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Cold fuel tank and warmer moist air equals condensation. It's doing the same thing on the inside if the tank is not full and why you hopefully stored it full of fuel.
