Tom/Barb wrote:
rgatijnet1 wrote:
I had a condensation problem during the Winter in the upper front cap on my Monaco coach. The only way I corrected it was to remove the shifting fiberglass insulation and replacing it with spray on two part foam insulation.
I have thought of doing that, and still may, But I have a few wires and cables up there that may some day need replacing.
For now, I've packed the area full of fiberglass insulation, we will see how well that works.
Most likely that will only get you soaked insulation. If it's condensation only air flow will keep it dry. If it's from a leak, you'll have ugly wet insulation which leads to mold.....Dennis
