John_Joey
Nov 16, 2014Explorer
Fleetwood Couple wrote:
There are no weep holes. This is the front windshield it's sealed up all the way around. The water was in the bottom frame of the window. I am going to see about locating a small dehumidifier. Not much left to run anything else. We're already shuting stuff off just to make coffee. 30 amp service is all we have.
Dehumidifier is the right answer, if you're living in the rig. 30 amps should be enough. I'm guessing you might be running an electric heater or two on the same line as the coffee maker. More then likely the line is a 15 amp breaker.
Good thing about a dehumidifier is if you can find a cheap used one in a second hand shop they usually are not very energy efficient and will throw off heat keeping you warm in the process.
