1L243 wrote:
It's in the 40's outside and the windows in the RV have alot of condensation inside the RV We have single payne windows. We have been using a radiant electric heater instead of the furnace to save on the propane, is this part of the problem?
nope,electric heater shouldn't be a source of humidity.
However, camping on the oregon coast in fall/winter/spring with high humidity and rain,= high humidity and condensation. We found that out our first trip to the coast in February.
Opening a vent helped, but under these conditions it didn't solve the problem.
Now, running a non vented propane heater can worsen the problem since for every gallon of propane you burn, 3 quarts of water are released into the air. that applies to the stove/oven. WH and furnace combustion air is vented to the outside so it won't put water into the interior air.
however, it isn't hard to have high humidity in a trailer from people, stove/oven, wet clothes etc. combine this with single pane windows, and condensation.
Our solution is to run a small compressor driven portable dehumidifier. About $100 for a decent one that is quite and reasonably small. It isn't uncommon for it to fill (4 gallons) up in 12 hours on the first day and then fill up every day after that. Picked one up at the Astoria FM the first time we ran into this problem.
Course, this only works if you have hookups or run the generator.
Advice, the small thermoelectric dehumidifiers aren't likely to remove enough moisture/day to solve the problem, nor wil dry the air things.
