Your not the first one. If there is only 1 person to help you back in it is hard to see every corner. The driver can't see the front corners of the MH while backing in. I had 3 people helping me back into a very tight spot with my MH I was going slow when I herd an noise I had hit a rod across the street that a solar light was on. Bent the rod but did no damage to the MH. The spotter at the back was watching the back and didn't see the rod. By the time we got set up and slides open the BR slide was about 1 ft. from the camper next to us. As I stated very tight spot.
