RoyB
Jun 09, 2018Explorer III
Show these drawings to your electrician... He will understand it... I would also hope he is a licensed guy with Insurance. If he ends throwing 240V at you in the wrong spot and burns up a bunch of things then his insurance will pay for it. If it is your friend or father-in-law etc... guess who gets to pay for it...
Typical camp ground Pedestal hookup
What to measure using the multimeter for RV 50AMP Circuit
What to measure using the multimeter for RV 15/20A and 30A Circuit
Are you sure you only need the 30A service? Check your shore power cable connector to see if will plug into the sockets shown here for 30A system setup... For some reason I have always thought the motorhomes were mostly 50A Service requirement...
Typical Service Pedestal at camp ground
All photos google images
Also check with your surge protector setup if you have one. Some have that built-in to their house setup. I don't use one on my simple off-road setup but have read this may not fit well into your house pedestal setup...
Don't let your Electical friend install anything based from 'his house wiring' experience. This is for RV's and there is a slight difference.
NOTE: DO NOT PLUG IN YOUR RV SHORE POWER CABLE until you read exactly what is shown using the multimeter chart readings. It can get expensive in a instant.
Read up on it on-line... Lots of stories...
Roy Ken
Roy Ken
38,780 PostsLatest Activity: Aug 05, 2026
