bukhrn
May 30, 2016Nomad
Your furnace blower is the biggest drain on your batteries,if you ran it constantly at 66 degrees, i'm sure it's dead, your fridge, running on propane uses next to nothing.
Your 24 series batteries are the worst, 27's would be better, sticking with 12V batteries, 31 series would be the best, IF the will fit in your battery tray without major modification.
If they are dead, running the generator for a minimum of 4 hours or more would be required to bring them back to full charge, this assumes that your converter is working properly & the size of the converter. Also, it would help a little to convert your lights to LED and get rid of the incandescent, LED's use far less power.
I also assume your water heater is running on propane, if not, i'm surprised your batteries lasted that long.
38,769 PostsLatest Activity: Apr 24, 2002
