CharlesinGA
May 31, 2016Explorer
classctioga73 wrote:
cgmartine
What's the recharge time on the 6 volt batteries?
Would they charge off the generator?
I've been hearing a lot of good things about 6 volt but also that they take longer to recharge
Would I need to upgrade my converter?
It is TWO 6v batteries in series, to make one big 12v battery. You do not need to do anything to your converter (unless it is single stage and you want to upgrade to a three stage) and yes, they charge off the generator (as it simply powers the converter) and also will charge off the chassis system if it is so wired now. Yes, they are larger capacity, thus can take longer to recharge if you discharge them very low.
Charles
38,769 PostsLatest Activity: Apr 24, 2002
