mikestock's avatar
mikestock
Connecting the towed battery to the 12 v house system
I made a fused jumper to connect along side of the regular tail light system. I ran + and - to the starter battery to be sure I had a good constant ground. I ran the same type fused jumper from my house panel to the back of the rv and have a 5 foot jumper to connect the two when towing. I added this because I added a Patriot electric braking system and wanted to be sure I didn't rune the towed battery down while towing.
My question is: should i install some sort of diode in the system to isolate the towed battery so that the current only can flow from the motor home to the towed and not vice versa? I always heard it was a bad idea to parallel different systems.
