hanko
Jan 27, 2017Explorer
wolfe10 wrote:
I see no reason for a diode-- that is unless you are dry camping and forget to unplug the charge wire.
And if you decide to use a diode, make sure it is not a standard one that "charges" around .7 VDC. That much of a drop will render the charge wire pretty well useless.
doent the 12 volt at the 7 wire plug run through and isolater. I know it does on my coach. the circuit goes dead when I shut the engine off on the motorhome
38,763 PostsLatest Activity: Dec 05, 2025
