mtrumpet
Feb 24, 2016Explorer
AstroRig57 wrote:
After selling our 32' Class-C gasser, and considering whether to go with a TT or Class-A motor home, we've decided on a Class-A and are now working on our "short list"
I thought I wanted another gas rig but, to my surprise, we've found a diesel pusher rig with which we are pretty well enamored. I know, you've probably answered these ad-nauseum, but here's a few questions I have.
The rig were looking at right now is a fairly late model, used, 36' Winnebago on a Freightliner chassis, 26,350 lb GVW. It has a 275hp Cummins Turbo Diesel and Allison transmission. My question is, is that engine powerful enough so a rig that size can even get out of it's own way? I know diesels have different torque characteristics than gas engines but have no idea if the 275hp Cummins would be considered a bit anemic for this rig or not? On steep grades, will we be the slowest thing on the road?
Also, in regard to the cost of fuel, the days of diesel being cheaper than gas are long since past especially in CA with the low sulfer diesel requirements. How does fuel mileage on a diesel pusher compare with that of a comparably sized gasser? Does better mileage offset the higher price of diesel or not?
I won't ask the questions re maintenance costs etc., as I've seen those pretty well covered. Also, this rig will be out at least 2-3 weekends a month so the "can I let it sit" question is a moot point as well.
Thanks
Although you won't win any races, that Cummins 275hp engine will be fine for that size of rig.
Unless I missed it, I do not see anywhere where the OP mentioned the model year of the unit in question, although, being a 275hp Cummins, I guess we have to assume late 90's/early 2000's. Having said that, does it come with air suspension? (Some older models did not.)
38,782 PostsLatest Activity: Sep 10, 2026
