Biggyniner's avatar
Biggyniner
Considering first DP - any advice?
Wife and I looked at an 03 Tiffin Allegro Bus, with the Cummins ISB 300HP and Allison 6 sp. 1 owner, always maintained at frieghtliner or cummins. I know from word of mouth both Allison and Cummins are a good combo. Is there anything specific I should check?
Also new to air brakes, what should I look for there?
He did mention that the thermostat/intake housing cracked and was replaced at 62k (currently has 64k on it) and at the same time they did the rear main...
  • Here's something that's mandatory for me. When you bring out the frontroom slide, do the storage compartments come out with it? Mine do. If they don't, it's a real PITA to get into the storage compartments that are back under the slide outs.
    Bill
  • Make sure you can get into things like the refer, bathroom and the sink while the slides are closed.
    Bill
  • ferndaleflyer wrote:
    300hp might be good for flat land but the one I had wouldn't get out of its own way and it was in a much smaller unit. 330hp is good but will struggle if you are towing something in the mountains. I currently have a 36ft Monaco with a turned up 330 and it does pretty good. That 300 isn't much in a bus.
    The current owner was honest about the hill climbing in it. Saying 40-45 whether towing or not, was to be expected on the grades.
  • 300hp might be good for flat land but the one I had wouldn't get out of its own way and it was in a much smaller unit. 330hp is good but will struggle if you are towing something in the mountains. I currently have a 36ft Monaco with a turned up 330 and it does pretty good. That 300 isn't much in a bus.
  • Bullet proof chassis and engine, change oil on time, enjoy, and don't pump the brakes.
