Gundog
Oct 03, 2018Explorer II
jplante4 wrote:
That's true of all rear radiator diesel pushers. On a CAT, the "slobber tube" (crankcase vent) dumps out under the engine and gets sucked into the charge air cooler and radiator. The fix is to build a slobber extension.
Some coaches have tried to solve this issue by putting the radiator on the side. In order to do this, they set up a maintenance prone hydraulic drive for the fan. Also, all piping is longer increasing the chances of a rock getting kicked up and causing a leak.
If you have a rear rad, yearly degreasing and cleaning is a must.
Do you have any more pictures of the slobber tube Mod?
