wolfe10
Oct 04, 2018Explorer
Gundog wrote:
My slobber tube is only about 1' long sticking straight down and the end is cut at an angle. I will have to do mine a little differently but with the same concept.
Thanks Mike
Yup, that is the common set up.
Easiest answer is to cut off the end square. Use a 1" barb to barb fitting and 4' of 1" ID hose for the extension. Will also need two hose clamps. Yes oil resistant hose is best, but even the cheap clear reinforced hose will last years.
Use zip ties to secure the extension-- again, making sure it only goes "down hill".
