Kidoo
Nov 17, 2014Explorer
Pogoil wrote:
Do not shoot the messenger but if $1-3 thousand scares you you do not want a diesel and may not even want to get into the RV. life style.
Service alone if done by a shop will cost you dearly. I do most all my own work and spend hundreds every year. Shop will be thousands every couple years and that is only if nothing breaks.
Just trying to be fair to you before you purchase.
Pogoil.
This is so true, I learned the hard way. I usualy do my oww mechanic. But this time, it was getting cold, tired of bending under, and I said, the heck with this, I will let the shop do it. I went for an oil change and fuel filters change: $244.00., "do we check the tires and grease and fluids", go for it I said: Oil and grease job done: $64.00. Check tire and put some air in it: $32.00, drop some antifreeze in: $20., plus coolant.
The only thing that was not bad was the ABS light On: $52 for the sensor, $150 for computor check and repairing the faulty sensor.
