RoysRV
Dec 02, 2014Explorer
Update:
I am still waiting on the generator, chassis, oil and coolant analysis, but here is what I have so far:
-PERFORMED A VISUAL INSPECTION. NOTED AN OIL LEAK. FRONT GEAR
HOUSING GASKETS APPEARS TO BE BLOWN OUT. INSPECTED OIL LEVEL.
INDICATING LOW OIL LEVEL.
-MUST ADD A 1 GALLON TO TOP THIS LEVEL TO THE FULL MARK. (ADDED OIL TO THIS ENGINE OIL CRANK CASE).
-ALSO NOTED AN EXHAUST LEAK AT THE OUTLET SIDE OF THE TURBO PIPE
CONNECTION. THE WELD HAS BROKEN OFF/CRACKED.
-DROVE AND SET THIS UNIT ON THE DYNO.
SET AND INSTALLED AN OIL PRESSURE GAUGE,FUEL GAUGE AND USED A HEAT
GUN FOR COOLANT TEMP VERIFICATION.
-RAN ENGINE TO RATED SPEED. HORSE POWER ON THIS ENGINE IS @ 155 TO
160 HORSE POWER. ENGINE IS RATED AT 250.
-OIL PRESSURE WHEN COLD START WAS 60 TO 70 PSI. WHILE ON DYNO RATED SPEED, THE OIL PRESSURE MAINTAINED 40 TO 45 PSI. AT IDLE ENGINE AT NORMAL TEMP OIL PRESSURE WAS 25 PSI.
-COOLANT TEMP ROSE TO 203 BEFORE THE COOLANT FANS CAME ON.NOTE
FANS ARE HYDRAULIC CONTROLLED. ENGINE COOLANT MAINTAINED @ 180 TO
200 DEGREES.
-INSPECTED FUEL PRESSURE OK (NOTE MANUAL FUEL PUMP WAS 25 TO 30 PSI.)
The manager is going to get me a quote on the repairs. So far, what is everyone's opinion?
200 DEGREES.
