JaxDad
Dec 14, 2014Explorer III
With your shore power cord plugged in disconnect the positive terminal of the chassis battery then turn on the ignition.
If the instrument cluster and radio come on, the converter is powering the chassis battery.
However based on my similar vintage Winnie, I think you'll find the chassis battery does not charge from the converter. In that time period Winnebago used a constant duty relay to link the house and chassis batteries together for charging from the alternator. The relay is only closed by the ignition circuit. If the ignition is not in the run position the relay is open.
