Bobbo
Dec 15, 2014Explorer III
The auxiliary battery switch disconnects the house battery from the house so it won't be drained over time the MH is unused. It also keeps the battery from being charged if plugged in. You will frequently see it referred to on this forum as a battery disconnect switch.
The auxiliary start switch, itself, is neither. However, it powers a massive relay that connects the two batteries together for starting/charging purposes. It is the relay that is powered by the auxiliary start switch that you want.
