ITguy
Nov 15, 2013Explorer
Finally found it under the stove, which is about at the midpoint of the MH, so about 16 feet from the batteries (which are immediately behind the grill). Looks like they went for close as possible to the power distribution center to make for easy wiring instead of close to the battery bank where it should be. Appears I have a 9155, so that's one purchase I can cross off the list.
Will be adding the Charge Wizard, though. Will also be relocate closer to the batteries, although I have other items higher on the priority list with winter quickly approaching. Also don't want to do that until I decide whether to increase from 2 to 4 batteries, which will require relocating the battery bank.
Thanks for the input!
38,766 PostsLatest Activity: Jan 10, 2026
