wny_pat1
Mar 26, 2014Explorer II
tiredkid wrote:Inquiring minds want to know about batteries that will last longer that the coach!!! Mine is twenty years old and on its third set.topflite51 wrote:tiredkid wrote:Give it a rest tiredkid, the THE OLD WIVES CLUB MEMBERS around here support 6 Volt batteries. No if's, and's or but's about it. :bphilandmargo wrote:
I have a 2000 Tiffin Zephyr. It has 4 deep cycle 12 volt batteries that power the coach. The batteries need to be replaced. I have heard that using 6 volt batteries is a more efficient and economic system. Can my system be converted? If so, how would I proceed? Thanks, Phil
Purchase four of these; Chrome Battery 12 Volt 110AH Deep Cycle
same size as a 27 series but they are AGM,these will last longer than the MH and u never fill them etc
cost about $900.you will Need 8 6 volts to do same job and even the cheap acid filled ones will cost you at least $800 plus all the work to convert
not interested in that club.Guy asked if he should stick to 4 good 12,s and same wiring and the correct answer is yes. if it aint broke don't try and fix it. especially with the quality of 12Volts available today of which were not available when you formed the old wives club.
