pianotuna
Mar 27, 2014Nomad III
Hi,
To be fair, you went from four 85 amp-hour batteries (when brand new) for a capacity of 340 amp-hours, which may not have been wired in a balanced manner, to four jars that store 464 amp-hours. Of course the new system works better--it is 27% larger in capacity. When you add the Puekert effect in, it is more nearly 33% larger.
If you had gone with four group 29 12 volt jars (115 amp-hours each) the capacity would have been about the same as the four 6 volt jars, and the results would have been again, a dramatic improvement. (wired in a balanced manner).
If we add a 2000 watt inverter to both the scenarios above, the 12 volt configuration would out perform the 6 volt one.
Since my new inverter is 3000 watts, I'm pretty much locked into 12 volt jars--and if/when I replace them I'll possibly go AGM for even better inverter use.
Four of the 12 volt jars are eight years old and still meet my needs.
Canadian Rainbirds wrote:
Last year I replaced 4 12V group 24 marine/rv "deep cycle" batteries with 4 6V GCs. The difference has been outstanding. I would never go back.
Same foot print, need more headroom.
