- Sandia_ManExplorer IIYou first wire two 6 volt batteries at a time in series (neg - to pos +) and now you have created two 12 volt battery banks that must be wired in parallel (neg - to neg - & pos + to pos +) before connecting them to your rig's DC system. Using the same length and diameter of wire throughout makes the set-up more balanced.
Whether you use 12 volt or 6 volt, it still boils down to total amphours, there are pros and cons to either set-up. We purchased our current pair of Interstate GC2 6 volt batteries from Samsclub and they have been providing reliable service over the past 4 years. We are utilizing a smart charging converter that keeps them healthy and strong, we try not to discharge them below 50% SOC, keep them clean and monitor fluid levels, although they rarely exhibit corrosion or require distilled water.
We were planning on adding a second set of golf cart batteries, but have not needed to since replacing all our incandescent lighting to LEDs. We run our onboard audio/video equipment throughout the day even when we're camping off the power grid, most times consuming a small portion of available amphours which is quickly restored via generator and Iota IQ4 the next morning while making breakfast. - wildtoadExplorer IIHave you ever run out of battery power? Have the batteries you have provided you with good service and lasted a good while? If the answers are (No, Yes) then leave well enough alone and replace them with like batteries.
- tiredkidExplorer
philandmargo wrote:
I have a 2000 Tiffin Zephyr. It has 4 deep cycle 12 volt batteries that power the coach. The batteries need to be replaced. I have heard that using 6 volt batteries is a more efficient and economic system. Can my system be converted? If so, how would I proceed? Thanks, Phil
Don't bother, reuse 4 new 12V deep cycle batterys.The cost and room and work involved does not outweigh any advantage to using Eight 6 volt batterys
especially if your using 4DM size 12 volt - smlrangerExplorerI would recommend going with six, 6 volt golf car batteries. Each pair of batteries must be wired in series, then you wire all the pairs together. If you have not done this before, I would recommend having it done by someone who is familiar with the process.
If you want the most maintenance free installation, go with AGM batteries. They are pricey, however. If you can easily get to the tops of the batteries to check/replenish water, standard lead/acid golf car batteries are great. - 1mtnmanExplorer II
This will help you understand what it takes to switch from 12 volt to 6 volt. 12 volt side of life - pianotunaNomad IIIHi Phil,
So long as there is room for twin six volts, yes it can. How many batteries do you have now? Make sure any change is wired in a balanced manner.
A well designed battery bank will work well what ever voltage is used. I.e. 2 volt are the best--but you need room for six of them. 12 volt is my preference because I use a medium sized inverter.
