rockhillmanor
Aug 02, 2016Explorer II
Its the nature of the beast and we ALL deal with the same problem. You get used to it and it will become second nature to you not to put plug in 2 items on at the same time. Same will happen if your DW uses a dryer, toaster etc. And appliance especially the ac draw more when they come.
snip it:
It’s important to note that in an RV you can’t run several appliances at once or you’ll blow your breaker. Here’s the skinny. Your RV has either 30 amp or 50 amp capability. Amperage is the amount of power available to use. Each appliance pulls a specific number of amps. Exceed 30 or 50 amps (depending on your rig’s system) and poof – the power overloads and the breaker trips. Here’s a handy list of some of the typical appliances and the approximate amps required to operate them:
Microwave 12.8 amps (depends on what type 500 or 1200)
Air Conditioner - 15,000 BTU 12.5 amps
Electric Water Heater – 6 gallon 12.5 amps
Toaster 10 amps
Hair Dryer 10 amps
Electric Frying Pan 10 amps
Electric Coffee Pot 10 amps
TV 2 amps
Crock Pot 1.5 amps
Heating Pad .5 amps
snip it:
Toaster 10 amps
Hair Dryer 10 amps
TV 2 amps
Crock Pot 1.5 amps
Heating Pad .5 amps
