bobndot
Aug 18, 2020Explorer III
If you plan to do this yourself , If the 1350 is a 13 cu ft how will you remove it and how will you replace it ? I don't think it's going to fit thru the door. If you have to remove a slide in order to swap it then its going to a bit pricey and might be worth repairing it thru an access service panel.
If you do not plan to do the work yourself then let whoever is figure it out as to what will fit and what wont. There are ice maker models as well to consider.
