holstein13
May 02, 2016Explorer II
Trap wrote:Unfortunately, my air system is powered by the engine. That's probably why it's not for long term use. Does your system also work while driving?holstein13 wrote:I do know that on our Monaco with Active air I have used air levelling for up to 2 months without any problems. Yes the compressor will cut in occasionally, as the levelling system wakes up every couple of hours and does a readjust.
I have both air levelers and hydraulic levelers on my coach so I will share my experience with you.
The air levelers are not designed for long term use. If I use them for one night, they are fine, but they don't work well for two nights or more. Furthermore, last week, I leveled with air and forgot about it for a couple of days and when I went to startup, the air level system didn't work at all. I had to shut down and restart to kick it off again. Newmar also recommends the hydraulic levelers for anything over one night.
The air leveling is not as stable as the hydraulic leveling either. You can definitely notice the difference in high winds where it will rock the coach slightly. Of course I'm 49,000 pounds so it's extremely stable either way, but you can notice the difference.
There are two great things about the air leveling system: 1) Ride height is automatically adjusted to match the crown of the road or steady wind conditions over long distances while driving. It will even lift the outside side when driving on a curve. 2) While parked, the system can quickly level and be comfortable. I use it virtually every time I park the coach at gas stations, rest stops, waiting to check in at campgrounds and any overnight stay.
I love my Hadley air leveling system but it's not the substitute for hydraulic that you might imagine.
We have both air and hydraulic and use the air 95% of the time.
38,778 PostsLatest Activity: Jun 10, 2026
