Stuck_in_firstExplorerNov 16, 2014Coolant capacityI have a 2000 workhorse (chevy) 454cu in. Does anyone know what the coolant capacity is? If I just drain the radiator can I refill and get the proper 50/50 mix?
John_WayneExplorer IINov 16, 2014How are you draining the engine block? If you don't drain the block when you add 50/50 it is no longer 50/50.
Related ContentRam 1500 Towing CapacityCoolant capacityWatch My DeGas Bottle Blow CoolantNo More 6.0 Liter Degas Coolant BoiloversTowing capacity
