ROYBUCK
Feb 18, 2014Explorer
wolfe10, the SCA in the coolant is OK, I am changing the coolant due to age, it has the ES Compleat extended service in it now will put the same back in. When it was changed the last time They (Cummins Atlantic in Kenly NC) put the WF2074 filter on I think it has the SCA in the filter. I don't have to much confidence in them when I bought this coach someone had written 24 Qts at the oil fill, oil stick showed over full no way will this coach hold 24 Qts. 221/2 at the most. I called Cummins they said 21 in pan. The reason I am asking about the filter I have a WF2074 on hand and also a non chemical filter on hand. In case anybody ask about the 24 Qts. it was in the Maint. records how much they put in. Thanks for all replies. Roy
