ROYBUCK's avatar
ROYBUCK
Coolant Change ( Hose'es thermostat)
I have a couple of questions, I know how to take care of the coolant change and what type. My questions are.
1. Do I put on a filter with the chemicals already added or one without the chemicals added, I guess I could call Fleetguard but thought maybe someone on here new.
2. Where can I get the Thermostat I know What Temp. I need, hate to go through Cummins if I don't have to.
3. Hos'es where can I get these will I go through cummins or Monaco don't know about Monaco due to the sale, If I go to NAPA will I need to take the Hos'es off and take with me, would like to have the hos'es before removing the old ones. I have a ISC 330
Thanks Roy
  • The filter will depend on what coolant you use -- The thermostat is probably a 180 degree -- You can get them on ebay when you find the part # -- The hose from the coolant tank is 1 1/4"-- I know this is not much help -- I have the 400 ISL -- If you get the hose from NAPA, get the one with the White Stripe --
