LarryLHExplorerJan 12, 2015Coolant leakI have a 2008 fleetwood Excursion with a rear radiator and a 360 hp ISC engine. There is a small leak that appears to be coming from the center of the engine below the front fly wheel or damper I thin...Show More
azrvingExplorerJan 12, 2015^^^^^^GeocritterDont put a sealer in it. Pressure test it and find the leak. Water pump, hose, hose clamp, o ring/ gaskets, rusted pipes.
Related ContentCoolant leakCoolant leakNautilus P1 has leaking connectionsCoolant tank leak on Freightliner7.4 Vortec coolant leak
