lj2654
9 years agoExplorer
Coolant leak
I am having an issue with a coolant leak on my 2001 Beaver Contessa with a 3126B CAT engine.
Last January the radiator and CAC were removed from the coach when I had a cracked fan replaced.
They installed the new fan backward and the motorhome ran hot. Once they went thru removing the Radiator and CAC, pressure and leak checked both.
They reinstalled the fan the correctly and put it all back together. Coach has ran fine since then with temps 186-192.....over a year ok.
Last trip of three hundred miles when I returned I checked coolant and was down 1 1/2 gallons.
I have looked from front of coach, heater core and hoses everywhere and to rear of coach after driving. No leaks at all and no antifreeze smell anywhere. I replaced the radiator cap and now it seems ok...temps good and no coolant loss after 200 miles of driving.
Could the old cap have been the issue? The recovery tank is steel and on top of the radiator and no leaks there.
