Jamster's avatar
Jamster
Coolant tank leak on Freightliner
Hi Everybody -
Taking off today thru the Nevada desert I discovered a pin hole leak on my Fleetwood Excursion Freightliner chasis. While small it was a steady stream and I had to go back to the RV park for a fix. Freightlner suggested JB Weld. I have "The Welder" epoxy / adhesive that is the same as JB Weld I feel.
Do you guys think - after overnight dry / cure per the instructions - this will hold? Coolant tank gets hot and high pressure of course. I've really not used an adhesive like this before but know it should fix almost anything.
I'm trying to not have to replace the entire coolant tank right now as I'm sure it would take time for the part to arrive and find somebody to install it. However I'm driving from Reno to Boise thru the desert and want to be smart about this.
Well anyway - now I get to stay put for my birthday - so I guess it's not all bad news ! ha ha
  • Update: Well I made It from Reno to Boise. Epoxy didn't work entirely. It developed a drip leak as opposed to the steady stream of yesterday. Temp was normal and levels didn't fall below the minimum line. While in Boise I will try and get the tank replaced. After only 7 years it has this leak but I've also found cracks at the joint between top and bottom. Man, is ANYTHING built to last these days? I'm having so many issues with my Fleetwood Excursion I'm feeling it's my Chaplin Breakaway House...
    • Brewski356's avatar
      Brewski356
      Did you have the work done in Boise and who did it?
  • Thanks Opnspaces and DancinCampers - both good suggestions ...
  • I would loosen the cap so it can't build pressure and test drive it. I've done that with my Suburban and it never heats up. Just monitor the temp but my guess is it will be fine.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      I would suggest that this is some solidly horrible advice.
  • I would use a sheet metal screw and rubber washer with the weld. If it leaked I would loosen the pressure cap and monitor the temp.
    • Grit_dog's avatar
      Grit_dog
      Trailblazer
      This otoh is great advice and about the most solid ad hoc repair plan.
      Even better if you find a screw with a rubber gasket like for metal roofs.
      Will work in the wet also. But if you can do the repair “dry” I’d use some more of the JB stuff, epoxy or even rtv on the threads to help glue it in.
      • StirCrazy's avatar
        StirCrazy
        Moderator
        Grit, instead of belittling and making fun of people, how about you actually throw some advice into the mix, if you know what is not right surely you know what is right, or are you just hear to make snippy comments and make people fell bad?
  • Hi Bud -
    Ok yes I should do that. Thanks for the reply.
  • This must be in the overflow pressure tank.
    I would not hold my breath on it holding. Call Freightliner near you for the new tank. I believe they changed material on new tanks.
