Grit_dog
May 20, 2025Trailblazer
This otoh is great advice and about the most solid ad hoc repair plan.
Even better if you find a screw with a rubber gasket like for metal roofs.
Will work in the wet also. But if you can do the repair “dry” I’d use some more of the JB stuff, epoxy or even rtv on the threads to help glue it in.
StirCrazy
May 24, 2025Moderator
Grit, instead of belittling and making fun of people, how about you actually throw some advice into the mix, if you know what is not right surely you know what is right, or are you just hear to make snippy comments and make people fell bad?
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
